Clutch problems
Old Feb 28, 2009 | 09:21 AM
tonys02slpss's Avatar
Question Clutch problems
I got new Centerforce clutch,throw out bearing,flywheel.I noticed that when I am shifting at high rpm like 4000-6000 rpm there is a lot of vibration in the peddle and feels like it barely lets go of it to shift to another gear?I also noticed sometimes when just driving normal that I shift into 3rd I let go of the clutch and it catches but then the car pulls harder like if it grabbed all the way.One time I was racing in 4th and was about to shift into 5th and it would not let go until the rpm dropped to like 4500 rpm?I know for fact they didnt bleed the system when they replaced all of that any suggestions will help.The clutch has been on there for about 6 months now.
Old Feb 28, 2009 | 09:41 AM
NJNETSFAN's Avatar
Well there's your problem. Go bleed it!
Old Mar 1, 2009 | 02:27 PM
eric1h's Avatar
SOunds to me like your pressure plate bolts are backing out, but try to bleed it first. But the vibration issue screams PP bolts.
