Need some input on swapping from auto to stick.
Motor is a 383 with a vortech. 650hp at crank. I have an ATI 3500 converter.
Questions I have:
Approximate cost of installing the trans myself. I can research all day but things are different when you actually do it. Any idea what cost would be minus clutch and finding a used master/slave stuff?
I'm using a stock 9" thirdmember, would this need upgraded?
The trans now is a th350 with a long tailshaft, so its about the same length as a 700, so driveshaft should work fine with a t56 right?
I was thinking of sending it to Tick later on to get sturdy. I just don't want to start this project, and find out I've run out of money and the car sits.
https://ls1tech.com/forums/manual-tr...requested.html
First thing I can tell you is NOT to use used hydraulics. Not worth it (used MC, maybe) It is just much of a PIA when it goes out, and since you are starting fresh, I would just go ahead and get new hydraulics.
9" will be fine.
Driveshaft is probaly gonna be different.
You can pick up a used T56 from anywhere from $1000-$2000 depending on what you get it with and what condition it is in, and what model. LT1 style is one style and teh LS1 is another. If you pick up a LT1 style, stay away from teh 93 model. '94 and up are good to go. The '93 is a one year only model that most parts will not interchange between the '94 and up.
If you browse teh classifieds, you can normally pick up a whole swap set up (tranny, clutch, bellhousing, pedals, shifter, crossmember, etc...) for $1500-$2500
With my power level, I'm a little weary about putting a stiff clutch in. The plan was to go with a spec 3. Would a stock clutch hold "most" of the power on the street?
I suppose a cable operated clutch would be about impossible with the push system eh? Would that be a bad idea anyway with a kick *** clutch?
I would go Monster, that's just me.
No, a stock clutch is not gonna hold 650 HP.
No, a cable clutch is not a bad idea at all, and it can be done, if you want to.
Seeing as the Lsx t56s (for the 5.3) are cheaper than the LT1, this might not be a bad route....and with a mildy built 5.3, an S10 would be plenty quick on the street....
