M6 conversion question
Old Mar 9, 2009 | 09:04 PM
thecamarokid's Avatar
Default M6 conversion question
A friend of mine swaped his A4 to an M6 and now after a few months of driving is having problems with the car not wanting to go into gear. After closer inspection we realized that the clutch is not getting enough travel because the floor board is flexing when you push in the clutch. My guess is that the factory M6 cars had a renforcment that the A4 cars did not have. Has anyone else had this problem or found a way to fix it?
Old Mar 9, 2009 | 09:47 PM
the_merv's Avatar
The M6 Cars don't have re-inforcement..is the metal torn in that area, have you looked into that area and seen if it's like that?
Old Mar 10, 2009 | 01:57 PM
Well when you look at the floorboard you can see a noticable flex in the floor. I can also tell when driving the car that the clutch does not have the right amount of travel. Maybe he just needs to put some sort of spacer where the pedal assembly bolts to the floor.
