New Flywheel?
Old Mar 12, 2009 | 08:17 PM
94m6Z28's Avatar
Default New Flywheel?
wrapping up my first larger build and i cant find any good pros/con on getting a new fly wheel, the stock one has probly been re-surfaced 2-3 times, is there any added benafit to getting a new steel flywheel over a stock unit?
clutch is a spec 3+ on a turboed 383
Old Mar 13, 2009 | 09:53 PM
94m6Z28's Avatar
no one knows?
Old Mar 13, 2009 | 11:18 PM
Awake455's Avatar
Wow, I didn't know there was enough material on an LT1 flywheel to be resurfaced 3 times. Might want to look into a replacement.
Old Mar 14, 2009 | 02:57 PM
BALLSS's Avatar
"benefit"...a steel FW typically is SFI certified.
the nodular iron is not. 3 resurfaces...might be getting to the point where a FW shim is needed.
I took my 'used" stock FW to Kragen for a "remanufactured" stock one for $30. ($130 FW-$100 core)
Old Mar 14, 2009 | 09:20 PM
94m6Z28's Avatar
what about clutch holding ability/ pedal feel and what not?
