Please Help!!! Bad vibration.....
Old Mar 22, 2009 | 07:14 PM
badblazeSS's Avatar
Default Please Help!!! Bad vibration.....
I just installed a Monster Level 3.....I drove it about 20 miles and started to get this bad vibration. When the car is in nuetral, it and rev it up to about 3000, it vibrates badly. Took it all apart and i am at a stand still. Thought is was the pilot bearing but it was great. Does the Monster flywheel come balanced? When i bolted the tranny back to the bellhousing, it would go to the dowl pins and would not go any further so i started some bolts and tightened it up so it would go on. When i took the tranny off today one pin was pushed through. My stock flywheel had alignment pins on it. I also thought the crankshaft had a pin on it to line up the flywheel. Mine did not. Any info would be greatly appreciated and thanks in advance.
