getting really mad
Old Oct 21, 2003 | 03:46 PM
StangSlayerSS's Avatar
Default getting really mad
ok guys i have a new pressure plate,disc, flywheel, slave, throwout bearing ,and rebuilt trans.I installed evrything bleed the master(which is an upgradeed gm unit)got all the air out ,so i thought
hooked up the quick coupling on the slave pumped the pedal about 50 times and bleed through the slave and my clutch pedal is still about an inch off the floor. i can start the car push the pedal down and move the shifter into 1st,2nd 3rd 4th , let up on the pedal and the tires move when the cars in the air but not on the ground. now it wont go into 5th 6th or reverse. I am going nuts im so close to being able to drive my car for the 1st time this year and its not working. someone please HELP
Old Oct 22, 2003 | 08:40 PM
unleashedss's Avatar
Default Re: getting really mad
This may sound crazy....but could you of installed your clutch backwards?
Old Oct 22, 2003 | 09:45 PM
no it dont sound crazy? i think i did the new one wasnt marked and i was having a dumbass attack i think . i'll find out when i pull it apart this weekend.
