LS6 Clutch Replacement
Old Apr 2, 2009 | 10:45 AM
S8ER95Z's Avatar
Default LS6 Clutch Replacement
I did some searching and the whole subject is messed up...
My car 'supposively' came with an LS6 clutch but people are saying it's not a 'real' LS6 clutch.. I want to replace the clutch with a new LS6 clutch and wondered if I need the kit or can just get the pressure plate, clutch, throwout bearing all seperate.
?? Anyone know?
I know a bunch of you guys have LS7, Spec, blah blah clutches...I drive 500+ miles a week and don't need a hard clutch to deal with so i am trying to stay with something that was as smooth as the stock one.
Thanks!!!
Part numbers and prices if you have them please.
Old Apr 2, 2009 | 12:39 PM
S8ER95Z's Avatar
In addtion... just started losing fluid from the resevoir and I have it on the ground under the car...does that sound like the slave cylinder or master cylinder?
Old Apr 2, 2009 | 01:32 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Get the LS7 setup. After it is broke in, it engages like stock
Old Apr 2, 2009 | 01:35 PM
m6speed's Avatar
+1, you won't notice a difference
Old Apr 2, 2009 | 02:23 PM
jakes4321's Avatar
Feels like stock!!
Old Apr 2, 2009 | 02:37 PM
S8ER95Z's Avatar
Thanks guys...I've heard that numerous times now... seems like the way to go.
Old Apr 2, 2009 | 02:51 PM
Z28/2002's Avatar
A couple of the sponsors are running an awesome deal right now on the setup, just FYI
Old Apr 3, 2009 | 06:07 AM
blkbird's Avatar
As far as the fluid on the ground, more than likely it is the slave. Oh, yeah, and it feels like stock (LS7)!
Old Apr 3, 2009 | 08:59 AM
S8ER95Z's Avatar
Thanks I dug around..looks like Im going to break 500 bucks doing this
Old Apr 3, 2009 | 09:05 AM
S8ER95Z's Avatar
That you was thinking the same thing, from what i've seen the throwout bearing is part of that?
Old Apr 3, 2009 | 10:12 AM
BanditTA's Avatar
LS7 feels completely different than stock, my CETA has an LS7 and my brothers stock LS6 feels entirely different.
Old Apr 3, 2009 | 12:59 PM
S8ER95Z's Avatar
Is the LS7 harsher? I guess...can you explain how they feel different? Thank you!!!!
Old Apr 3, 2009 | 02:10 PM
Z28/2002's Avatar
Mine felt stock but I guess every car is different
And yes the throw out bearing is part of the slave cylinder.
Old Apr 3, 2009 | 04:14 PM
m6speed's Avatar
i had an ls6 clutch in my 98 and an ls7 in my 02, they feel about the same, at first the ls7 was close to the floor but after breaking it in the engagement was higher. it feels close to the same if not the same.
