Convert a4 to m6 reflash
I have LS1Edit and the guys at Carputing helped me sending the right program.
No problems going from A4 to M6 (and back, if I want!) but the program has to be be the right one.
Anybody that can tune can tune it to make it work.
Probably better off having a local tuner do it. The dealer wants to re-flash w/ a stock M6 tune. All you need is the auto changed to the m6. Post in the tuning section & ask for a local member in your area. Am sure that someone on here who is local to you (w/HP tuners) will help. You could also do a mail order & just have them do the ms6 part.
Things like neutral switch, clutch switch, VSS & one or two others will either have to be confirmed or turned off, based on how you did the swap. So, this information is important to the tuner. Good-luck
There are enough hiddden settings that change from A4 to M6... not just speedo and obvious things like shift points or so.
You don't need to change the VIN. You even can go to a GM dealer and let them load a M6 program keeping the original VIN using TECH2. If they don't know how let me know because there's a trick
