Input shaft!
Old Apr 10, 2009 | 12:29 AM
Jrp1978's Avatar
Default Input shaft!
How much play should be on the input shaft ? when i changed clucth noticed there was back and forth play on input shoaft.... How hard is that bearing to change? Detail it for me start to finish on input shaft !
Old Apr 10, 2009 | 12:35 AM
Project GatTagO's Avatar
There will be some play since the input shaft is meant to be supported by the pilot bearing.
Andrew
Old Apr 10, 2009 | 08:50 AM
thesource's Avatar
A little side to side movement is common . You do not want in and out .
