SBC to LS1 trans?
Old Apr 12, 2009 | 09:34 PM
ATX ENGINE MAN's Avatar
Default SBC to LS1 trans?
Will a LS1 6 speed work behind a standard SBC? What would I need to do about a pressure plate? Thanks for any input.
Old Apr 13, 2009 | 06:51 AM
85MikeTPI's Avatar
The McLeod 8710-10 bellhousing should allow a direct fit. You can also swap over the input shaft/Mid-plate/Bellhousing from a LT1 trans, and use all the LT1 4thgen Fbody clutch setup.
