Clutch pedal return spring
Old Apr 18, 2009 | 09:17 PM
95 Z28's Avatar
Default Clutch pedal return spring
I'm not even sure what exactly it's called. The little U shaped spring assembly that helps to return the clutch pedal to it's resting position. Well, I've replaced mine twice after they both failed. I know some guys say "F it" and run it with no spring but I don't like the play that the pedal has at the top with no spring. Has anyone made a custom spring setup or anything like that?
Old Apr 18, 2009 | 11:34 PM
areax's Avatar
+1.. Mine is broken as well and I would like to find a better spring or make a beefier spring to put in there so I don't have to fix it again.
