OK shim help
Old Apr 26, 2009 | 06:19 PM
Jrp1978's Avatar
Default OK shim help
Where do i find these slave shims gonna try shim clutch before i go with a new one! I have asked several times and good way to tell if it pressure plate or something else is going wrong but no one had good answer!~ i have textraila with tic slave and cant shift i high rpms and still jumps forward in first at 300 rpms . Yes i have adjusted and adjusted and bleed and bleed mity vac tell i was blue in face . It shifts great putting around town but will not even move if i hit 500o rpms
