What is making this noise?
Old Apr 30, 2009 | 02:05 PM
blitzed96's Avatar
Default What is making this noise?
When I have it in second and come to a stop with the clutch to the floor it makes this noise.
Old Apr 30, 2009 | 02:06 PM
blitzed96's Avatar
I just had the trans rebuilt and this is on the drive after putting it back in.
Old Apr 30, 2009 | 02:31 PM
SPEC-01's Avatar
Does the car make that noise with the pedal released at idle or just in 2nd gear? I ask because it appears that you move it to neutral and the sound is still present? It sounds like gear noise in the video which is normally associated with use of a lightened flywheel and results from the reduced dampening of these units compared to a stock steel unit. Let me know more about when the noise is heard and I will be happy to provide more info. Thanks!
Old Apr 30, 2009 | 02:47 PM
blitzed96's Avatar
I pulled up to the stop sign in fourt the same way and it didn't make the noise. It has done it in first and second. As soon as I leave off the clutch it stops.
Old May 1, 2009 | 08:21 PM
blitzed96's Avatar
Any other ideas? I don't want to ruin anything else.
