Help with cylinder issues I THINK..
Alright, about a month ago my clutch pedal lost the hydraulic feel to it, it would go down way to easy and such so I checked the fluid and it was almost empty, thought nothing of it though so I filled it up and it was all good to go. Now just this week it was doing it AGAIN, I checked the fluid and its empty, filled it and it's alright for now. I'm guessing this is either the master or slave cyl leaking.. but im not sure how to find out what one it is and if that is indeed the problem. I can sit there and pump the clutch for 10minutes and the fluid level remains the same, it seems to take about a month for it to leak out so its a small leak wherever it is. Problem is, im about to do a camswap and im guessing the extra power from that will cause bigger problems with the leakage.. so I wanna figure out what it is and fix it before hand or at least know what it is so when the clutch goes ill just get a ls7 setup. Any ideas on how to tell where this leak is coming from or any advice? Thanks
