clutch questions
Old May 3, 2009 | 08:47 PM
T-56SLPSS's Avatar
Default clutch questions
Hello mods are in sig. I did a clutch swap 7 months ago along with a new slave and master and now im having some problems hoping you all can help. My problem is under high rpms after one shift the clutch pedal will not come off the floor and will not go in gear. I have changed the fluid and im thinking its my slave cylinder but im not sure. its also starting to slip after i let off the clutch petal and catch a moment later.. any help will be greatly appreciated thanks
Old May 3, 2009 | 09:49 PM
taws6m6's Avatar
You need to look into the drill mod and upgrade to the 01-02 hydraulics
Old May 5, 2009 | 12:48 AM
T-56SLPSS's Avatar
okay the drill mod is for the bottom of the master cylinder right? and 01-02 hydraulics? is that the master cylinder, slave cylinder or the whole thing?
