what to replace with tranny out
Old May 5, 2009 | 11:29 PM
hotpocket's Avatar
Default what to replace with tranny out
i'm gonna swap my clutch in about a week. just wondering what you all recommend i replace or adjust while the transmission is out. so far i'm replacing: flywheel, pressure plate, slave cylinder, master cylinder.
i don't want have to do anything for awhile so i want to be as thorough as possible this time (short of rebuilding it).
Old May 9, 2009 | 10:16 PM
metalmechanic's Avatar
trans mount bushing, poly
Old May 10, 2009 | 02:36 AM
slayerized6's Avatar
DONT FORRGET THE PILOT BEARING!!
get a remote bleed before you button everything back up. will maket he bleeding process 100x easier.
poly trans mount is a nice upgrade if you want less movement, less than $20 at autozone.
Old May 10, 2009 | 04:07 PM
99LS6SS's Avatar
and possibly poly torque arm mount. Maybe check your u-joints since your drive lines out.
Old May 10, 2009 | 05:05 PM
Wesmanw02's Avatar
Rear main seal and rear main cover gasket. Better to change it now than later!!
