need trans / hydraulic help
Old May 9, 2009 | 11:29 PM
EW WS6's Avatar
Default need trans / hydraulic help
so this weekend I just rebuilt my trans with all new bearings, races, billet keys, bronze pads, and toleranced it. Installed the trans and I bled the hydraulics to where the clutch pedal is stiff and how it was before. The car will go into gear and back into neutral just fine. But the clutch will not disengage. The hydraulics and clutch that i am using are the same as last time before i rebuilt my trans. The master cylinder I have is adjustable so I am wondering if that has something to do with it or if I still has air in the line. Any help would be great. Thanks guys
Old May 11, 2009 | 08:46 AM
Jonathan@Tick's Avatar
LS1TECH Sponsor
How can it go into gear just fine if the clutch wont dissengage? Are you saying it will go in just fine with the engine off, but not when the car is running?
Old May 11, 2009 | 09:47 PM
EW WS6's Avatar
with the rear wheels in the air and no resistance it will go into gear and back out just fine without using the clutch
