LS7 problem
Old May 13, 2009 | 02:50 PM
S-sguy's Avatar
Default LS7 problem
Put a full brand new ls7 clutch asembly in my ss, flywheel,pressure plate, and clutch. But now iv have vibration around 2000-2500 rpms while the cars moving and wen its sitting still, clutch in or out. And on the road 6th gear vibrates real bad wen doin about 70 wat is the deal any info is much appreciated
Old May 13, 2009 | 03:55 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I would go back and double check the flywheel bolts and everything else
Old May 13, 2009 | 07:47 PM
91rs350's Avatar
i dont know what to tell you..but i dont go into 6 until like 75-80...maybe that will help
Old May 13, 2009 | 09:58 PM
S-sguy's Avatar
iv double checked everything is tight..i was wondering if maybe its the throw out bearing
or something this is making me so mad...
