rebuild/upgrade
Old May 14, 2009 | 12:27 PM
z28rob18's Avatar
Default rebuild/upgrade
hey guys ive been readin through here about what ppl are doin to upgrade there t56 and i need some parts info. the car should be putting down about 700hp and in that range for torque. will be using a twin disk and the car will be raced quite a few times. i need to know what parts i need to upgrade to keep my trans runnin ok. right now it has no problems at all. i was lookin at the stage 2 kit from tick but was hopin to spend a little less on parts. is there anything in the stage 2 that i dont need? wat would you reccomend for my trans?
Old May 14, 2009 | 12:29 PM
thesource's Avatar
You are right at the edge of what a stock unit can handle. I personally would suggest going to the Viper out put shaft for a little more peace of mind.
Old May 14, 2009 | 12:34 PM
z28rob18's Avatar
wat i was thinkin was upgrade the forks, keys and get the output shaft cryo treated. i know thats about the limit of the stock t56 but it has 165k miles so i figured it may need more but if thats all you guys think it need thats all ill do.
Old May 14, 2009 | 03:15 PM
thesource's Avatar
Having the main shaft cyro'd will do little if anything.
Old May 14, 2009 | 03:18 PM
z28rob18's Avatar
alright ill look into the viper shaft and the few things i mentioned.
Old May 14, 2009 | 06:19 PM
99LS6SS's Avatar
Get the level 2 rebuild from tick and the viper main shaft kit i think you can get from D&D. Or just have tick do the Viper Level 3 build for you and that should be more than enough for you.
