please help torque arm mount
Old May 17, 2009 | 09:55 AM
s10pro's Avatar
Default please help torque arm mount
car was had a th400 in it, going to a 6 speed, arm has a polly mount on it do they both use the same mount please help thanks
Old May 17, 2009 | 11:29 AM
93cz28's Avatar
i know with the 4l60 trannies you can use the same rubber mount but the bracket is different,should be the same with the th400 cuz its the same torque arm. also gonna need the bracket on the other side that holds the exhaust.so your gonna need the 6speed brackets.
