T-56 ?sss
Old May 23, 2009 | 03:36 PM
Kmaroman's Avatar
Default T-56 ?sss
When I bought my car over a year ago the owner before put a B&M short shift in it. Well it wasn't until yesterday when i had the center console off i realized the 4bolts holding it to the top of the transmission where all loose. Anyways the actual top plate had some play in it. On top of that my car grinds in 2nd gear sometimes, it all happens so fast I don't know if it when the clutch is pushed down or not. Sometimes it does it other times it'll be fine. It just 2nd gear though, what could cause this, its like a real quick grind noise then its fine. It only does it once per trip driving it doesn't matter it seem's to be more often then note when I'm giving it about half throttle.
