How to shorten?
Old Nov 6, 2003 | 08:39 AM
01Z28MN6's Avatar
Default How to shorten?
just installed a pro 5.0 and want to shorten the stick about half an inch, what is the best way to perform this?
Old Nov 6, 2003 | 10:13 AM
ChiefBrody's Avatar
If there's extra thread on the top of the stick you could grind it down. Maybee even thread it down a little farther after you grind it. I don't think it would be worth it to cut and weld for half an inch. The other option might be a LSS, there pretty cheap.
Old Nov 8, 2003 | 10:35 PM
14u2nv's Avatar
Take your shift **** off. Put a few small drops of paint on the very top of the stick and then put the **** back on. Tighten the **** all the way until you like it, then slowly take it back off. The paint you put on will be tracked down the threads by the ****'s threads. The amount of threads that has paint of them is the amount of threads you need to hold the **** on correctly. Then take the stick off and place it in a vise. Use a hacksaw with a good/new blade and cut off the threads leaving only what you need(the amount of threads that had paint on them,remember). With a good sharp blade the hacksaw should cut through the stick quite easily.
