clunking trans??
Old May 27, 2009 | 12:53 AM
therobman's Avatar
Default clunking trans??
i have a 2000 ta with a t56 i just changed the torque arm bushing and trans mount and checked my torque arm when i shift if i let off the clutch to fast i get a clunking sound is that normal or can i do something to change this it really bothers me. maybe motor mounts they are stock with 41k on them
Old May 27, 2009 | 08:50 AM
Gen414's Avatar
was teh noise their BEFORE you changed TQ arm bush? Or just after?
WEll, normallly a motor mount problem you will notice when you "accelerate" instead of "decelerating". Are you sure it is not coming from rear end?
Old May 27, 2009 | 09:39 AM
UCABlackChevy's Avatar
Got the exact same problem after pulling the trans to install new clutch. Some have said the trans mount may be loose, I will check it this weekend. If you find out what it is before then let me know.
Old May 27, 2009 | 10:37 AM
therobman's Avatar
positive and its before and after the install and i just got a new clutch its better but still there
Old May 28, 2009 | 12:08 PM
therobman's Avatar
k i removed the center console and rubber boot and took it out for a drive the trans was not moving it seemed like it was the exhaust or tq arm any ideas?
