need how-to for t56
Old May 27, 2009 | 05:07 PM
explicit.muscle's Avatar
Default need how-to for t56
im looking for a how-to write up on the t56. I need to replace the reverse synchro, and hopefully without dropping the tranny.
Thanks guys
Old May 27, 2009 | 05:10 PM
araber89's Avatar
From: Holmes County (thats right Amish Country), OHIO
Not to sure if that possible to do... Just drop it it will be easier to work on.
Old May 27, 2009 | 05:22 PM
85MikeTPI says it possible by removing the crossmember and removing the tail section of the tranny.
Old May 27, 2009 | 05:38 PM
araber89's Avatar
Maybe it is then. I figured you couldn't get there but hey it worth a try
Old May 27, 2009 | 05:39 PM
the_merv's Avatar
Veteran: Air Force
You have to get the Tail Shaft off.
Old May 27, 2009 | 06:58 PM
Torkman15's Avatar
10 Second Moderator
Much easier to do on the floor. Prob easier to remove in one piece too...
Good luck with that.
Old May 27, 2009 | 07:21 PM
so is there any place I can get a how-to? doesn't have to be on how to do it with the tranny still on the car, just on how to change out that reverse synchro
Old May 27, 2009 | 08:33 PM
the_merv's Avatar
Veteran: Air Force
You need to get the Tail Shaft off and pull the Reverse Gear off so you can get access to the Slider/Synchro assembly.
What exactly is yours doing?
Old May 28, 2009 | 09:46 AM
Bad Blue WS6's Avatar
theres a ton of them on here, searching helps.. but most of what you;ll need is in the stickies...
https://ls1tech.com/forums/manual-tr...-write-up.html
https://ls1tech.com/forums/manual-tr...s-rebuild.html
https://ls1tech.com/forums/manual-tr...eed-input.html
https://ls1tech.com/forums/manual-tr...al-sticky.html
https://ls1tech.com/forums/manual-tr...-tomarrow.html
https://ls1tech.com/forums/automatic...-question.html
http://ls2.com/forums/showthread.php?s=&threadid=1877
Good Luck!
Old May 28, 2009 | 11:48 AM
i accidently threw it into reverse while racing(don't ask me how, cuz I dont even know how I got it past the lock-out). the reverse gear works perfectly, but is a bitch to get it into the gear, so i ground the synchro to shreds. And thanks Bad Blue. Thats exactally what I was looking for.
Old May 28, 2009 | 02:07 PM
your welcome. I just found that last one, and its a REALLY good one, lots of pics.
Old May 30, 2009 | 02:41 PM
bearcatt's Avatar
It's possible but why. It's would make so much more sense to do it right and drop the tranny.
