Changing clutch fluid
just search "how to bleed hydraulics" in the search for how to bleed the clutch. you can either do:
the old fashioned 2 person (1 pumping the pedal, 1 opening the bleeder)
1 person method (drill a hole in the trans tunnel and pump pedal/open bleeder with one person
or the you could use a mityvac
