M12 shiftiing a reverse issues! PLEASE HELP
Old May 31, 2009 | 02:01 PM
Jrp1978's Avatar
Default M12 shiftiing a reverse issues! PLEASE HELP
ok so here is the story!
i have a 402 that makes right at 500 hp 480 trq its in a 2002 chevy camaro! A while back the clutch got covered in oil and i took all apart a cleaned.
the clutch is a x grip texatraila about 7000 miles on it. Ok before i had the oil leak i was having issues with clutch grabbing bad and not shifting at high rpms at all ... Almost like it was locked into place . I was told to try ticks slave with i did and still same thing grabs bad and will not shift at all at high rpms. I have bleed and bleed and luck . I am also smelling clutch disk when i do try to shift it at higher rpms.
should i just order a new clutch .... If so witch type can i reuse tex pressure plate or should go with whole new one?
i would really like to say i just could shim slave and it would be ok but i am sure the oil soaking didnt help and it has all new hydro .. I mean what else would make it shift so hard or drag beside a worn clutch or not shimmed right! I dont want to shim it just to have to replace it because of the oil.
also when all this happen i picked up a bad vibration some where ?
anyhelp would rock.....
what clutch would u all reccomend for trouble free install with no shimming and ticks new master cylinder!
would a bent fork cause all this ? The m12 is new 6000 or so miles on it?
Old May 31, 2009 | 02:03 PM
Jrp1978's Avatar
Default Also
Also when i had it apart last time with only 6000 miles i noticed i was down to rivet on one of the clutch pucks?
Old May 31, 2009 | 02:04 PM
spaz1's Avatar
Mcleaod rst clutch and there is no clutch fork.. unless it is a lt1 tranny
Old May 31, 2009 | 02:07 PM
Jrp1978's Avatar
Default K
I meant forks inside transmission
Old May 31, 2009 | 09:01 PM
Jrp1978's Avatar
Default Anyone else !
More input ???
Old Jun 1, 2009 | 11:52 AM
bearcatt's Avatar
Based on the information given ... it sort of leads one to believe that your problems might be clutch related.
With most aftermarket clutches, it's a good idea to measure to see what and if a shim is needed.
If your clutch had oil all over it, that can't be a good thing. If I was dropping the trans, I would have replaced it.
The Textralia is a popular clutch, however there a other great clutches on the market too... Diamond, Monster, Spec3+ to name a few.
The MN12 trans you have is a nice trans, I have one and love it. I myself prefer the OEM LS7 clutch and Tick but I'm not at the horse power level you are. I also don't launch hard or drag race.
Old Jun 1, 2009 | 01:41 PM
Jrp1978's Avatar
Default ok
thanks bearcat! i am forsure lost thinking myself it pressure plate and clutch are just shot ! I guess i will go with a new clutch !
Old Jun 1, 2009 | 02:31 PM
bearcatt's Avatar
I hope you get that thing working correctly ...
