Tick Performance Adj. Master???
Old Jun 3, 2009 | 09:51 PM
DTB_LS1's Avatar
Default Tick Performance Adj. Master???
I have a Tick Performance adj. master cylinder on my car and I recently had to re-adjust it a little because my tranny was hanging in gear. My question is, do I have to re-bleed the hydraulics after I have made the adjustment?
Old Jun 3, 2009 | 09:56 PM
MeentSS02's Avatar
Kleeborp the Moderator™
An adjustment should not require a rebleed. You only need to bleed the system if there are air bubbles in it somewhere, or if it has been opened (like disconnecting the master from the slave).
Old Jun 3, 2009 | 10:08 PM
DTB_LS1's Avatar
Ok cool. The problem I'm having now is the car is still hanging in gear a little but it doesn't happen all the time which leads me to believe that there is air in the system or could it be that I have to adjust the m/c a little more? When I made the initial adjustment I turned the rod in 1/2 turn increments. Should I try to fine tune it with 1/4 turns or should I just bleed the system and go from there?
