Clunk from Bellhousing
So the first thing I did was rebuild the transmission and change to an Ls7 clutch, flywheel, pilot bearing, slave cylinder, and then bleed it. A month later I lost the clutch pressure because of a defective slave cylinder. So this time the dealership pulled the tranny because I did not have the time. The only charged the labor because the part was under warranty. It was hard to get in gear for a bit but it sorta just started to shift perfectly. One day I noticed the car had a vibration at 70-90 miles per hour.
I figured it was wheel out of balance. So I balanced all my wheels in class. The vibration continued so I was going to do a NVH test on it (Noise Vibration frequency test). When I lifted the rear wheels to drive it 70 I heard a terrible clunk sound. So i left it in 5th and jumped out to see where the sound was coming from. Sounded like it was from the bell housing. The clunking was not as bad when I let it run in 2nd gear. It is a loud clunk and it goes away in neutral so its not engine related. Also when driving the car with wheels on the ground obviously, I do not hear any clunk at all. Can someone explain what is wrong with my car now, and why it makes that sound when lifted off the ground??? Thanks guys for any help or advice
i'm more of a novice with cars, but if the sound is more noticeable when the wheels are spinning faster (5th gear compared to 2nd gear), the problem is likely atleast past the transmission, too.
