slave connection
Old Jun 18, 2009 | 01:37 PM
keving711556's Avatar
Default slave connection
replacing a bunch of stuff, i am currenty stuck getting the quick disconnect back into the new replaced slave, any ideas?
car is a 2k camaro, slave is the upgraded one..
Old Jun 19, 2009 | 08:24 PM
RARON455's Avatar
When replaced my clutch setup I bench bled my MC and then tried to put it in the car I had that problem too, it would not go into the slave, I just pushed in on the little port tab in the center of the line and released the pressure on the line and it went right in like it was supposed to, then bled it again in the car. Hope this helps.
Old Jun 19, 2009 | 11:17 PM
Arc00TA's Avatar
Yes, this is like any other QD you have to relieve the pressure before it will click in. Just poke the plunger in with a screwdriver a tiny bit and then it will pop on with no problem.
Old Jun 20, 2009 | 08:32 AM
that was exactly it, and I had to clean it up to make sure I got a good grip on it.
Old Jun 20, 2009 | 09:19 AM
DJB's Avatar
DJB
12 Second club
Open the bleeder on the slave,slap it in and then close bleeder back.
