hydro problems or something else HELP!
Old Jun 25, 2009 | 10:23 PM
nerisls1z's Avatar
Angry hydro problems or something else HELP!
ok so here's the problem feels alittle tight going into gears...only 2nd gear grinds at wot , tried the drill mod today still the same thing tried the mighty vac i was getting bubble all day....took out the master took apart cleaned (stock master) put back together bled again alittle better but every so often at wot still getting grind going into second gear thats after bleeding from under car ...Its hard when the only person you have is 56 year old father trying to pump a clutch pedal...so another thing ive read is that rp trans fluid is no good so im going to grab penziol tommorow to see what happens and try bleeding more.....I'll take any wild guess to what it might be ...also has new centerforce clutch slave an oe master... gathering funds to grab a aps kit an other mods this is anoying please help
