grinding going into third?
Old Nov 13, 2003 | 08:32 PM
soldier6552's Avatar
Default grinding going into third?
Tonight was the first time I drove my car in a pretty good amount of rain, it would grind a little when I transfered to 3rd each time unless I let the tach/RPMs level back out before I did it. Any Ideas on why this could be happening, its fine when its dry outside. TIA
-JOSH
Old Nov 15, 2003 | 11:52 AM
anyone got any ideas?
Old Nov 15, 2003 | 12:44 PM
TATER's Avatar
Mine does the same thing. Except sometimes it won't go into 1st at a stop, or third at mid-RPM's. I'm going to install a D&D rebuild kit and see how that works. I'm thinking it's worn out synchros.
Old Nov 15, 2003 | 12:58 PM
camarossdn's Avatar
I would say its the synchros. Start saving for a rebuild. It will be fine for a while just don't miss a gear.
Good Luck.
Old Nov 15, 2003 | 01:19 PM
ALPINE's Avatar
Mine does the same crap, my syncros have about 3k on them. Problem is I've got a cam going in and I wont be able to get into gear at 6300 or 6400.
Old Nov 18, 2003 | 03:30 PM
NMPD's Avatar
-JOSH
I have a Mazda Protege with the same problem, grinding every 3rd shift or so. I'm a great driver, and I know its not me so I think its the synchros.
Old Nov 18, 2003 | 04:20 PM
black_z's Avatar
Definetley sounds like the synchros.
