T56
Old Jul 9, 2009 | 02:17 PM
noobzilla1's Avatar
Default T56
Hi everyone,
I'm building a tube frame car and I'm planning on using the LS1/T56 combo. I don't want to dish out $4000 for the engine and transmission yet, and I've been looking around for mock up engines and transmissions. I found an engine, but I can't find a T56 with an LS1 bell housing.
There's a local guy who's selling a "core" with no bell housing, but it's from a 94 LT1. I was wondering if it's possible to use a 93-97 T56 with an LS1 bellhousing. Can anybody help?
Thanks in advance!
Old Jul 9, 2009 | 11:40 PM
Gen414's Avatar
You need a midplate as well (along with teh bellhousing) and the input shaft is different (but should not matter for you since you are only using it for mock up)
Also, the 93 is by itself, 94-97 is another and then 98-up.
Now, is the midplate and bell the same on teh 93 and 94-97? I believe so (believe it is jsut internal that is different)
What I am 100% on is if it is 94-97, then YES, it will work with a midplate and bellhousing swap and MAYBE if it is a 93
Old Jul 10, 2009 | 12:16 AM
SlideRight's Avatar
whats this midplate you keep mentioning? i have worked on my t-56 but i havent removed the clutch or bell housing.
Old Jul 14, 2009 | 12:43 PM
noobzilla1's Avatar
Thanks for your reply. What exactly is this midplate you're talking about?
Old Jul 14, 2009 | 01:38 PM
the_merv's Avatar
The very front plate of the Transmission..it's what the LS1 Slave or the LT1 Fork bolts to.
Old Jul 14, 2009 | 03:00 PM
Gen414's Avatar
It is what The merv just said. You have teh transmission, than midpalte (about 1 1/2-2" thick) than teh bellhousing. When looking at teh transmission from the side, look at where the bellhousing meets the "tranny"....that is actually the midplate. Then if you go back another 1 1/2-2" you will see another parting line, and that is the end of teh midplate. The midplate (and input shaft) is different on LS and LT cars because teh LT uses a clutch fork and teh LS does not (obviously)
Old Jul 14, 2009 | 03:06 PM
Gen414's Avatar
Here is a pic of a LT T56, from left to right.......Bellhousing, midplate (it is the part that has the cut-out where the clutch fork is) than the tranny itself:
And here is an LS T56 (can you see teh difference in midplates?)
