Blew the clutch?
Old Nov 16, 2003 | 10:01 PM
BadAndy's Avatar
Default Blew the clutch?
Last Fri I was at the strip. On my first run I spun really bad in 1st so I shortshifted to second at about 5000rpm. As soon as I hammered it into second, the tach needle just layed voer at 6500. So I threw it into third and the same thing happened. So iburned the clutch up pretty bad on that run and a couple more after that. Then I noticed it started grinding going into third gear, and it has gotten progessively during the weekend and now the shifter will not stay in third gear with out being held there. Also, THere is a weird rattling noise coming from where I would think the bellhousing would be. It is present at idle and intermittintly during driving. Could that just be crap falling of the clutch and rattling around in there?
