pro 5.0 problem
Old Jul 30, 2009 | 06:18 AM
ginop524's Avatar
Default pro 5.0 problem
so i had the tranny and clutch done on my car this past week (full rebuild on tranny and monster stg 2 clutch w/ lightweight flywheel). after i get the car back i realize that the shifter is dead to the left and right direction (no firm snapback to the center position, just falls where it may). does anyone have a parts diagram of the pro 5.0 or know what is the reason may be? are their springs in the shifter that hold it tight that might not have been put back on correctly? any advice would be appreciated. thanks in advance
Old Jul 30, 2009 | 04:46 PM
INMY01TA's Avatar
Normal, mine did the same thing. Pretty much have to take it apart and change the springs for heavier ones.
Old Oct 1, 2009 | 10:49 PM
97Z28SS's Avatar
Where can the heavier springs be purchased and does anyone have a diagram, I just brought a used Pro 5.0 shifter and want to fix any issues before I install it.
Old Oct 2, 2009 | 12:08 AM
99Bluz28's Avatar
Lightbulb
First remove the stick from the shifter, then take off the 4 Allen head bolts from the center section. The two parts(upper, and lower) should pop apart. You can install a small washer above each spring to give the springs more tension.
If you can find some stiffer springs to use, I'd like to know also.
Old Oct 2, 2009 | 12:10 AM
dutinsss's Avatar
that's weird, mine was fine right out of the box.
Old Oct 2, 2009 | 12:19 AM
LargeOrangeFont's Avatar
Old Oct 2, 2009 | 12:34 PM
94Z28rag's Avatar
I did this: https://ls1tech.com/forums/manual-tr...heap-easy.html
Worked like a charm.
