weird bleeding issue...need help?
Old Jul 30, 2009 | 09:07 PM
ChaseSS's Avatar
Default weird bleeding issue...need help?
I just put in an LS7 clutch, new slave, and new master and I have a remote bleeder... I bench bled the master and when trying to connect the line to the slave I did lose a little fluid (if that matters)... now when I go to bleed the system, the pedal seems to never stiffen. I have 1 bottle of fluid in it (I don't know how much fluid total the system takes?) but I would only get a little bit of pressure on the pedal and then none the next time... I got frustrated and left for an hour and come back to find the pedal with almost full pressure, tried bleeding then and lost all the pressure.
Whats going on? Could there be a leak on the remote bleeder letting air in so I'm not getting anywhere? There is no fluid leaking from the bell housing either. I have no idea why there was pressure after I left it alone for an hour
PLEASE HELP!!
Old Jul 30, 2009 | 11:53 PM
ChaseSS's Avatar
went out and got a power bleeder.... problem solved
