Replaced the clutch & slave....problems...
The whole job sucked, as Ive never done it before, but it was simple enough. After putting everything back together I have 2 very noticeable problems that Id like to see if anyone has insight on:
1) Clutch engages about 3/4" from floor. This I feel can be remedied by a shim....but that means taking it ALL back apart. Gah. Synchros feel like they're working hard to get it in first, less in other gears, and not at in to R.
2) Theres a very noticeable "whurring" noise coming from the clutch assmebly area. It revvs with the engine, happens in all gears and with the clutch in & out. I was pretty careful and don't think theres anyway I left something hanging on the flywheel?? Any ideas?
Also, seems like no matter how much I bleed the slave there are still bubbles every once in a while in the line. Im praying the master doesnt need to be changed too, this has already gotten pricey.
