Should i replace my flywheel????
I also suggest checking the flywheel for flatness after machining to make sure that it is truly flat. I do not recommend using a lathe to accomplish this because the father the tool moves away from the center line the greater the amount of flex it can experience and thus the less consistent the surface will be. Take the flywheel to a machine shop and ask them to use a blanchard grinder to surface the flywheel. Make sure they take before and after measurements to insure that they do not over-machine it.
The other option is to buy an aftermarket flywheel. We offer both steel (SC75S) and aluminum (SC75A) options. If you let me know a bit more about what you plan to do with your car (in terms of power upgrades and usage) I will be happy to make a recommendation for you. Keep in mind that steel is less expensive and will retain more stock-like drivability characteristics. I hope this info helps. Let me know if you have any further questions. Thanks!
