Clutch problem, what the hell.???
Old Aug 31, 2009 | 09:09 AM
charlie c5's Avatar
Originally Posted by rice8er
the line should be extreamly hard if not imposible 2 get on the slave if u don't crack the bleeder screw so maybe u damaged the o-ring or something. pull the line & check
Your talking about the o-rind on the master cylinder hydrolic line that plugs into the slave, and not the seal thats on the slave side.? Im just making sure. Of course Ill check everything.
Old Aug 31, 2009 | 11:10 AM
ScreaminRedZ's Avatar
registered user
Originally Posted by Gen414
If you continue to get air, you are not getting it all out, and your setup will not be right.
I had the vacuum pump hooked up to it for several hours yesterday and there was no sign of the bubles stopping. That's what is making me think it might be sucking air in somewhere.
