catch can on t56?
Old Sep 8, 2009 | 05:55 PM
Wesmanw02's Avatar
Originally Posted by YellowB4Z
I run royal purple synchromax in my T56. Its a little thicker than standard Dexron. Also if you are hot lapping the car it could be getting hot expanding the fluid and/or aerating the fluid causing it to take up more space there for sloshing towards the back on hard launches forcing it up the vent tube.
How do you know for a fact that the Royal Purple fluid is "thicker"?? I'm assuming you mean its a higher viscocity, but I can't see how that works being that it needs to meet Dexron III/Mercon specs.
Old Sep 10, 2009 | 08:46 AM
Sartobuilt's Avatar
Look at your shifter where it mounts to tranz. My car did the same thing when I got it. I pulled the console and the bolts were loose.
