T56 conversion
Old Nov 30, 2003 | 03:24 AM
natefletcher152's Avatar
Default T56 conversion
I am putting a T56 trans into my 1967 camaro. i want to use my stock clutch linkage which is a push style. the new transmissions as all pull style and i was curious if there was an adapter i can use and how much does it cost. if not what do i need to do to get the job done.
Old Dec 1, 2003 | 07:49 PM
John B's Avatar
Moderator
Welcome aboard! Which year T56 are you using?
Since the OEM T56's use hydraulic actuated linkage you will either have to modify your existing clutch pedal (and do away with your manual linkage) to obtain the proper geometry for the master cylinder linkage rod or buy a pedal specifically set-up for the hydraulic linkage rod.
