what speed sensor do i need?
Old Sep 22, 2009 | 04:41 PM
LT1TA's Avatar
Default what speed sensor do i need?
I have a bad transmission which i plan on replacing soon. i also do not have a working speedometer. i notice that many places list a speed sensor, and a transmission speed sensor. which do i need to buy? from the illustrations, they look like different parts. will a bad transmission speed sensor cause the computer to throw codes and not go in certain gears?
Old Sep 23, 2009 | 05:33 PM
LT1TA's Avatar
help???!!
Old Sep 23, 2009 | 07:08 PM
iansane's Avatar
Are the places you're looking refering to a trans speed sensor and a wheel speed sensor? If your cluster doesn't work, I would be looking at the trans speed sensor and/or the wiring to it.
Old Sep 24, 2009 | 01:03 PM
jmd's Avatar
jmd
Speedometer is fed from the PCM but the PCM is fed from the VSS in the tail of the trans.
Not going into certain gears is mechanical; unrelated to VSS issues.
Old Sep 24, 2009 | 02:50 PM
LT1TA's Avatar
mmhhmmm ok, thanks guys. i will get this resolved asap now.
