New Tic performance master cyl and same issue??????????????????????/
Old Oct 10, 2009 | 06:48 AM
1FSTLS1's Avatar
Default New Tic performance master cyl and same issue??????????????????????/
I got my new master cylinger installed and went to the track last night. Before I could not get 3rd or 4th gear now I can get all the way down the track 3 out of 4 passes and 1 time I had to pump the pedal twice to get 4th gear. Still managed to get 13.0 on that pass. So the clutch definatly feels better but still not right as after every pass the peadal was stuck to the floor in 4th gear and have to pump it to get it to work again. What am I doing wrong do i have a bad slave? (slave was put in whith the cluth maybe 2000 miles ago but the installer did not change the fluid ) Can any one point me in the right direction.
Old Oct 10, 2009 | 09:58 AM
Gen414's Avatar
well, I would THINK that you still have air in line. Can I ask how you are bleeding it?
Old Oct 10, 2009 | 12:47 PM
1FSTLS1's Avatar
Did the mighty vac and traditional bleed. Guess I could go at it more but I cant imagine more air in there.
