Dropping T-56 got Question
If you haven't drianed the transmission fluid yet, now is a good time, because the transmission will need to be tilted slightly to clear the exhaust (at least in a 2000 Camaro), and it will spill out the back of the transmission.
Drain fluid from tranny first.
For hydraulic/MC line, get you a small coffe can/plastic cup, etc...as when you disconnect MC line, you wll get some fluid that will come out of MC line. Not a whole lot, but it can make a mess, especially if in your driveway...
