Defect with Ram pressure plate?
It's obvious that the drilling that occurred during balancing did this. There is a hole right behind the dimple. Looks like the drill didn't go all the way through, but it was very very close. The dimple does protrude off the surface of the disc a couple hundredths.
I ask this for 2 reasons.
(1) This is an *obvious* bump. As soon as the motor starts turning, this bump is going to tear across the clutch disc pads. Now, I'm no expert, but that doesn't sound like a real good idea. Of course I could drill it out...
(2) This will leave a hole in the pressure plate disc. I don't think it's a big deal, but I want to check and make sure before I install this thing.
It doesn't give me warm fuzzies, so I'm not going to install this until I get a good answer.
-Andrew
Havent seen that before, Allan is going to take a look at the pics when he gets in and I shot an e-mail to Mike @ Ram to come in and take a look at it. Will get you some info on this asap.
Thanks
Candy
