Flywheel Recommendations
Old Nov 2, 2009 | 07:46 PM
gh94z28's Avatar
Default Flywheel Recommendations
I have had it resurfaced once already and i bought it used. How many times can you resurface them?
Old Nov 2, 2009 | 08:49 PM
slayerized6's Avatar
depends on how materal much was milled off each time it was resurfaced. at max, i would only resurface a flywheel once; after that, you risk having to pull the trans down if theres no enough material.
Old Nov 3, 2009 | 09:49 AM
gh94z28's Avatar
Thanks that's what i was thinking.
Old Nov 3, 2009 | 10:22 AM
SNLPerformance's Avatar
If you don't feel comfortable with your stock flywheel we sell our setups at a great price. They will work with many aftermarket clutches including the stock pressure plate. We sell the 28lbs flywheel for $249.99 and my 18lbs units are $299.99.
