lowering transmition
Old Dec 9, 2003 | 06:36 PM
pdd's Avatar
pdd
Default lowering transmition
is there a special attachment i can put on my floor jack to lower the transmition? or do i have to buy a special jack? im doing the job on jackstands.
Old Dec 9, 2003 | 06:55 PM
rodent's Avatar
I got one like this for my large floor jack. Works pretty good except you have to get the car pretty high, otherwise the tranny and jack is still too tall to clear the bottom of the car. Make sure you got the wide stance type of jack and not the cheap skinny kind you get at Walmart.
http://www.harborfreight.com/cpi/cta...itemnumber=507
Old Dec 10, 2003 | 12:26 AM
pdd's Avatar
pdd
any other special tools ill need?
Old Dec 10, 2003 | 12:42 AM
ta12sec's Avatar
At home in the garage a 16 inx16in of 1/4 inch plywood and a ratchet strap work great.
Old Dec 10, 2003 | 05:30 AM
Slowhawk's Avatar
LS1Tech Sponsor
There should be a writeup somewhere for a clutch install in a Vette.It is not the same as a F-body.I was told you have to drop the front subframe.
Old Dec 10, 2003 | 03:00 PM
pdd's Avatar
pdd
thanks for the replies guys. i have the helms manual. so ill go for there
Old Dec 10, 2003 | 06:30 PM
WILWAXU's Avatar
Yeah.. lowering a Vette transmission is a whole other animal.
