Hard to shift when running through the gears
Old Nov 25, 2009 | 07:08 AM
Tripdagoat's Avatar
Default Hard to shift when running through the gears
I swapped an ls2 6 speed combo out of a 2006 gto into my 78 Malibu. Stock engine, transmission, clutch, new GM clutch slave and master ordered for a 2000 ss camaro. Here is my problem, I drive the car normally its fine, when I run through the gears shifting at about 6k and by the time I go to shift 3rd the pedal feels like its on the floor, pumping it does not help, and i have to wait to catch 3rd, let the car recover for about 5 to 10 seconds and i can shift again. Clutch slave is bled properly no air in the system. I have heard a bad slave cyl will do this, but a brand new one from GM?
Old Nov 25, 2009 | 05:00 PM
AFASTYZFR1's Avatar
Get a Tick master cylinder!
