spec, mcleod, or Ram
Old Dec 15, 2003 | 07:28 PM
BDD's Avatar
BDD
Default spec, mcleod, or Ram
I am in the process of doing h/c project. Which clutch is best for me. The car should make around 420 rwhp and it will be driven mostly on the street, but I do drag race it quiet a bit. Maybe you guys can tell me the pros and cons of each clutch.
Old Dec 15, 2003 | 07:57 PM
JRcamaroZ28's Avatar
I really like my RAM VDS 910. it holds great. will be adding a 12-bolt and cant wait to drop the clutch w/ this set up. Its a non slip but once you get the hang of it its no problem and if you have 4.10's or more in the rear its not that bad.
JR
Old Dec 15, 2003 | 08:23 PM
Slowhawk's Avatar
LS1Tech Sponsor
I had a RAM and it blew with 1500 miles on it.Peddle pressure sucked bad.
Have a Mcloed now and holds great,but my friend has had serious issues with his not holding the power.
So
I would suggest SPEC..There new design seems to be working good and I'll be installing one soon in the spring.
Old Dec 15, 2003 | 09:01 PM
SSean's Avatar
I'm really likeing my spec stg3 so far. I drive it everday, in rushhour traffic at that and its performing great. Pedal feels firm and consistant. I also have the mcleod adj master cylinder also. Great combination so far
Old Dec 15, 2003 | 09:26 PM
mike c.'s Avatar
I have the RAM 910. this is my 4th clutch and the best sofar.its been smooth,no chatter w/3.73's(it's better with the 4.10's now)the pedle is not stiff and its held my 430hp pulling the front wheel off the ground.its been a great street clutch and when me and my n.o.s wear it out,i will buy another ram 910. i'm also in michigan 70mi north of detroit,where are you at?- goodluck to ya.
Old Dec 16, 2003 | 09:22 AM
BDD's Avatar
BDD
Yea I think I will go with the Ram, but I am still not sure. By the way I live about 30-40 miles north of detroit, in a little town called Romeo.
Old Dec 16, 2003 | 02:34 PM
mike c.'s Avatar
call allen at futural motorsports! thats where i got my ram he will take care of you.get the entire ram setup;w/the flywheel,you can NOT use any flywheel but the one for the ram clutch.if you try to use stock or someone elses it will kill the clutch ALOT sooner. i think i paid $800 or so for the whole set up,this clutch has been good to me. GOODLUCK TO YA. ps. if you need someone to install it,give me a yell. i'll set you up with the shop that did mine,great work and really good prices.
Old Dec 16, 2003 | 06:23 PM
BDD's Avatar
BDD
What do you guys think about the Ram VDS 980. Will it hold still? How bad would it be driving around town on the Ram VDS 910 with 3.42 gears and a 228R 112lsa cam?
Old Dec 16, 2003 | 06:56 PM
770Guy's Avatar
I have a spec stage 3 clutch, and I absolutely love it. Feels like stock, I give it complete hell and it hasnt failed me yet. Mods are in sig.
Old Dec 17, 2003 | 01:25 PM
jeffgdula's Avatar
I have a RAM 6130 now and like it alot but it sounds to me like the 910 is what you need. My roommate has the SPEC stg. 3 ceramic on his and it isnt too bad either.
Old Dec 17, 2003 | 03:14 PM
TTPMatt's Avatar
The new SPEC Stage 3 x-pad has been working very well of late. We have installed 15+ of them and have sent over 50 out the door in the last few months.
The x-pad usually does not chatter too much in the break-in period.. After 4/500 miles and a little abuse this thing feels great.
Easily slippable in traffic, I've driven spec 3's in the cross bronx/gwb traffic all the time.
- Matt
Old Dec 17, 2003 | 04:25 PM
Scalpel's Avatar
- Matt
Are all of the SPEC clutches for the LS1 SFI approved?
Old Dec 17, 2003 | 11:33 PM
14u2nv's Avatar
I too have the 6130/402 RAM VDS in my SS and I love it. I also have a 1st design SPEC stage 3 carbon in my 00 Ws6 with a stock master cylinder and a new updated slaved. The SPEC is a decent clutch but I like my RAM much better. If I were you I would call Mikey at Rapid Motorsports and he'll point in the right direction!
