Low traction engaging
Old Dec 16, 2009 | 09:26 PM
Bossds333's Avatar
Default Low traction engaging
When I am sitting at a stop with the clutch in and the tranny in first, my low traction light come on and i feel it working the ABS through the pedals. I only started doing this a month ago and very seldom but now it seems to happen almost all the time. I have an 02 Z28 M6 with some suspension and 85k on the Odo. Any help you guys could give me would be greatly appreciated because I want my baby to run perfect.
Thanks
Derek
Old Dec 17, 2009 | 08:51 AM
dschmittie1's Avatar
It does it while you are not moving at all?? either way if you are having an ABS or traction control issue your problem is more than likely a wheel speed sensor than anything else.
Old Dec 17, 2009 | 09:16 AM
eseibel67's Avatar
Agreed. Most likely resitance problem with one of the sensors. Trouble code and scan should identify the culprit.
Old Dec 17, 2009 | 09:25 AM
Not always. alot of times with problems like that the problem is in the sensor itself and it will drop the signal a little early making the EBCM think that a wheel locked up. Happens alot and will 90% of the time not set a code. You have to drive around with the scanner and watch to see witch wheels speed sensor drops out. can be a bad sensor or broken wires loosing continuity at times. Most of the times though the ABS only sets codes when there is a HARD fault.
Old Dec 17, 2009 | 04:23 PM
Bossds333's Avatar
Default Thank you
I am going to have my buddy hook it up to the scanner for me, im sure he wouldnt mind if we took a little drive with it either.
