Bleeding a Clutch
Now, if you are like me, you couldn't reach the bleeder from the bottom of the car, although other people evidently can. So after some cursing, I slid back the carpet and drilled a 7/8" hole in the body trans tunnel about where I guessed it would be, so I could put a socket on the bleeder from inside the car, and then I can do the whole bleeding thing from inside the car, single-handed. I plugged the hole with a rubber plug and put duct tape over it.
The clutch hydraulics are self-adjusting, and it sounds like bleeding will help you.
